[Geoserver-devel] [jira] Created: (GEOS-995) Align WMS reflector and KML reflector
                 Key: GEOS-995
                 URL: http://jira.codehaus.org/browse/GEOS-995
             Project: GeoServer
          Issue Type: Improvement
    Affects Versions: 1.5.0-RC3
            Reporter: Chris Holmes
         Assigned To: Justin Deoliveira
             Fix For: 1.5.1
This is pretty minor, but basically there is some code duplication between the two reflectors. Which wouldn't be the worst thing, but the WMS reflector is now better. The KML one should be improved to be able to pass every property through if needed. Right now its selective on what gets through. It should also allow one to set the onLoad time, and maybe set the default a slight bit lower.
