I am suddenly unable to load new geotiff files into an old GeoServer instance (2.15.2).
The latest log entries are:
> 2021-06-01 12:27:16,920 ERROR [geowebcache.GeoWebCacheDispatcher] - null https://geoserver.test.edu/geoserver/gwc/service/tms/1.0.0/rtofs:rtofs_qf_20171123_0000@anonymised.com:4326@anonymised.com/10
> 2021-06-01 12:27:16,920 ERROR [geowebcache.GeoWebCacheDispatcher] - Request failed
> java.lang.ArrayIndexOutOfBoundsException
> 2021-06-01 12:36:44,743 ERROR [geowebcache.GeoWebCacheDispatcher] - null https://geoserver.test.edu/geoserver/gwc/service/tms/1.0.0/rtofs:rtofs_qf_20180323_0000@anonymised.com:900913@anonymised.com/16
> 2021-06-01 12:36:44,743 ERROR [geowebcache.GeoWebCacheDispatcher] - Request failed
> 2021-06-01 12:38:41,224 ERROR [geoserver.rest] - Error while storing uploaded file:
> org.geoserver.rest.RestException 500 INTERNAL_SERVER_ERROR: Error while storing uploaded file:
> at org.geoserver.rest.catalog.AbstractStoreUploadController.handleFileUpload(AbstractStoreUploadController.java:93)
> at org.geoserver.rest.catalog.CoverageStoreFileController.doFileUpload(CoverageStoreFileController.java:451)
> at org.geoserver.rest.catalog.CoverageStoreFileController.coverageStorePut(CoverageStoreFileController.java:142)
> at sun.reflect.GeneratedMethodAccessor550.invoke(Unknown Source)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at java.lang.reflect.Method.invoke(Method.java:498)
> at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:207)
> at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:137)
> at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:102)
> at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:895)
> at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:800)
> at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:87)
> at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1038)
> at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:942)
> at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:998)
> at org.springframework.web.servlet.FrameworkServlet.doPut(FrameworkServlet.java:912)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:651)
> at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:875)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
> at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:292)
> at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:207)
> at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
> at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:240)
> at org.apache.catalina.filters.CorsFilter.handleNonCORS(CorsFilter.java:437)
> at org.apache.catalina.filters.CorsFilter.doFilter(CorsFilter.java:177)
> at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:26)
> at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:69)
> at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:73)
> at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:66)
> a2021-08-19 15:21:54,602 ERROR [geowebcache.GeoWebCacheDispatcher] - null https://132.177.103.242/geoserver/gwc/service/tms/1.0.0/gomofs:gomofs_qf_20200316_0000@anonymised.com:900913@anonymised.com2…/8
> 2021-08-19 15:21:54,602 ERROR [geowebcache.GeoWebCacheDispatcher] - Request failed
> 2021-08-19 15:21:56,818 ERROR [geoserver.rest] - Error while storing uploaded file:
> at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:41)
> at org.geoserver.platform.AdvancedDispatc2021-09-17 15:37:09,554 WARN [geoserver.web] - Error saving authentication config
> com.thoughtworks.xstream.io.StreamException:
> at com.thoughtworks.xstream.core.util.QuickWriter.flush(QuickWriter.java:77)
> at com.thoughtworks.xstream.core.util.QuickWriter.write(QuickWriter.java:49)
> at com.thoughtworks.xstream.io.xml.PrettyPrintWriter.writeText(PrettyPrintWriter.java:279)
> at com.thoughtworks.xstream.io.xml.PrettyPrintWriter.writeAttributeValue(PrettyPrintWriter.java:227)
> at com.thoughtworks.xstream.io.xml.PrettyPrintWriter.addAttribute(PrettyPrintWriter.java:222)
> at org.geoserver.security.GeoServerSecurityManager$FilterChainConverter.marshal(GeoServerSecurityManager.java:3415)
> at com.thoughtworks.xstream.core.TreeMarshaller.convert(TreeMarshaller.java:70)
> at com.thoughtworks.xstream.core.TreeMarshaller.convertAnother(TreeMarshaller.java:58)
> at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.marshallField(AbstractReflectionConverter.java:274)
> at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter$2.writeField(AbstractReflectionConverter.java:250)
> at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter$2.<init>(AbstractReflectionConverter.java:213)
> at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.doMarshal(AbstractReflectionConverter.java:144)
> at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.marshal(AbstractReflectionConverter.java:90)
> at com.thoughtworks.xstream.core.TreeMarshaller.convertAnother(TreeMarshaller.java:43)
> at com.thoughtworks.xstream.core.TreeMarshaller.start(TreeMarshaller.java:82)
> at com.thoughtworks.xstream.core.AbstractTreeMarshallingStrategy.marshal(AbstractTreeMarshallingStrategy.java:37)
> at com.thoughtworks.xstream.XStream.marshal(XStream.java:1319)
> at com.thoughtworks.xstream.XStream.marshal(XStream.java:1308)
> at com.thoughtworks.xstream.XStream.toXML(XStream.java:1281)
> at org.geoserver.config.util.XStreamPersister.save(XStreamPersister.java:663)
> at org.geoserver.config.util.XStreamUtils.xStreamPersist(XStreamUtils.java:68)
> at org.geoserver.security.GeoServerSecurityManager.saveSecurityConfig(GeoServerSecurityManager.java:1608)
> at org.geoserver.security.web.auth.AuthenticationPage$4.onSubmit(AuthenticationPage.java:229)
> at org.apache.wicket.markup.html.form.Form.delegateSubmit(Form.java:1309)
> at org.apache.wicket.markup.html.form.Form.process(Form.java:976)
> at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:797)
> at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:708)
> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
> at org.apache.wicket.RequestListenerInterface.internalInvoke(RequestListenerInterface.java:258)
> at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:216)
> at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.invokeListener(ListenerInterfaceRequestHandler.java:241)
> at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.respond(ListenerInterfaceRequestHandler.java:234)
> at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:895)
> at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
> at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:265)
> at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:222)
> at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:293)
> at org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:261)
Running a stable script, I now get:
> File “C:\Users\geoserver\AppData\Local\HyOc\lib\site-packages\geoserver\catalog.py”, line 462, in create_coveragestore
> self._create_coveragestore(name, data, workspace, overwrite)
> File “C:\Users\geoserver\AppData\Local\HyOc\lib\site-packages\geoserver\catalog.py”, line 524, in _create_coveragestore
> raise UploadError(r.text)
> geoserver.catalog.UploadError: Error while storing uploaded file:
Any suggestion on how to resolve this issue?
