Chris Chen created an issue |
j_spring_security_check returns http instead of https when putting geoserver behind Nginx proxy |
Issue Type: |
Affects Versions: |
2.18.6, 2.19.6, 2.20.4 |
Assignee: |
Unassigned |
Created: |
14/May/22 4:38 PM |
Priority: |
Reporter: |
Hi, I ran into the issue when trying to put geoserver behind Nginx proxy and enabling SSL. I tried GeoServer version 2.18.6, 2.19.6 and 2.20.4, all got the same issue that, j_spring_security_check returns http://xxxxx/geoserver/web, instead of https://xxxxx/geoserver/web I’ve updated the web.xml with: <context-param> Nginx config: server { ssl_certificate /home/cert/7371305__xxxxxx.com.pem; location / { proxy_pass http://127.0.0.1:8080/geoserver/; proxy_pass_header Set-Cookie; proxy_set_header Host $host; proxy_set_header X-Forwarded-Proto $scheme; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; proxy_redirect off; } location /geoserver/ { proxy_pass http://127.0.0.1:8080/geoserver/; proxy_pass_header Set-Cookie; proxy_set_header Host $host; proxy_set_header X-Forwarded-Proto $scheme; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; proxy_redirect off; } } |
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100198-sha1:8950bff) |
