After setting everything up and getting things up and running… the jms-clustering configuration wouldn’t sync because classes are not added to the XStream security configuration.
javax.jms.JMSException: org.geoserver.cluster.impl.events.configuration.JMSGlobalModifyEvent
at org.geoserver.cluster.client.JMSQueueListener.onMessage(JMSQueueListener.java:161)
at org.springframework.jms.listener.AbstractMessageListenerContainer.doInvokeListener(AbstractMessageListenerContainer.java:736)
at org.springframework.jms.listener.AbstractMessageListenerContainer.invokeListener(AbstractMessageListenerContainer.java:696)
at org.springframework.jms.listener.AbstractMessageListenerContainer.doExecuteListener(AbstractMessageListenerContainer.java:674)
at org.springframework.jms.listener.AbstractPollingMessageListenerContainer.doReceiveAndExecute(AbstractPollingMessageListenerContainer.java:318)
at org.springframework.jms.listener.AbstractPollingMessageListenerContainer.receiveAndExecute(AbstractPollingMessageListenerContainer.java:257)
at org.springframework.jms.listener.DefaultMessageListenerContainer$AsyncMessageListenerInvoker.invokeListener(DefaultMessageListenerContainer.java:1186)
at org.springframework.jms.listener.DefaultMessageListenerContainer$AsyncMessageListenerInvoker.executeOngoingLoop(DefaultMessageListenerContainer.java:1176)
at org.springframework.jms.listener.DefaultMessageListenerContainer$AsyncMessageListenerInvoker.run(DefaultMessageListenerContainer.java:1073)
at java.base/java.lang.Thread.run(Thread.java:829)
Caused by: com.thoughtworks.xstream.security.ForbiddenClassException: org.geoserver.cluster.impl.events.configuration.JMSGlobalModifyEvent
at com.thoughtworks.xstream.security.NoTypePermission.allows(NoTypePermission.java:26)
at com.thoughtworks.xstream.mapper.SecurityMapper.realClass(SecurityMapper.java:74)
at com.thoughtworks.xstream.mapper.MapperWrapper.realClass(MapperWrapper.java:125)
at com.thoughtworks.xstream.mapper.CachingMapper.realClass(CachingMapper.java:47)
at com.thoughtworks.xstream.core.util.HierarchicalStreams.readClassType(HierarchicalStreams.java:29)
at com.thoughtworks.xstream.core.TreeUnmarshaller.start(TreeUnmarshaller.java:135)
at com.thoughtworks.xstream.core.AbstractTreeMarshallingStrategy.unmarshal(AbstractTreeMarshallingStrategy.java:32)
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:1421)
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:1399)
at com.thoughtworks.xstream.XStream.fromXML(XStream.java:1284)
at com.thoughtworks.xstream.XStream.fromXML(XStream.java:1275)
at org.geoserver.cluster.impl.handlers.configuration.JMSConfigurationHandler.deserialize(JMSConfigurationHandler.java:42)
at org.geoserver.cluster.impl.handlers.configuration.JMSConfigurationHandler.deserialize(JMSConfigurationHandler.java:19)
at org.geoserver.cluster.client.JMSQueueListener.onMessage(JMSQueueListener.java:155)
... 9 more
26 003 23:03:50 WARN [client.JMSContainer] - Setup of JMS message listener invoker failed for destination 'queue://Consumer.f7faa9cccbd2.VirtualTopic.geoserver' - trying to recover. Cause: org.geoserver.cluster.impl.events.configuration.JMSGlobalModifyEvent
26 003 23:03:50 WARN [client.JMSContainer] - Execution of JMS message listener failed, and no ErrorHandler has been set.
javax.jms.JMSException: org.geoserver.catalog.event.impl.CatalogAddEventImpl
Caused by: com.thoughtworks.xstream.security.ForbiddenClassException: org.geoserver.catalog.event.impl.CatalogAddEventImpl
at org.geoserver.cluster.impl.handlers.catalog.JMSCatalogEventHandler.deserialize(JMSCatalogEventHandler.java:57)
at org.geoserver.cluster.impl.handlers.catalog.JMSCatalogEventHandler.deserialize(JMSCatalogEventHandler.java:28)
... 9 more
