[Geoserver-devel] [JIRA] (GEOS-10558) DescribeFeatureType response contains mixed content when one type does not exist
Jason Newmoyer (SUB) created an issue
GeoServer / BugGEOS-10558
Issue Type:
BugBug
Affects Versions:
2.21.0
Assignee:
Unassigned
Components:
WFS
Created:
23/Jun/22 3:51 PM
Environment:
CentOS 7
Priority:
MediumMedium
Reporter:
When invoking WFS 1.1.0 DescribeFeatureType using multiple types via TYPNAME param, if one of the layers is not available (or has some type of error when generating the schema), you’ll end up with mixed content in the response - basically you can end up with JSON with an XML exception concatenated to it as per below:
https://myserver/geoserver/wfs?service=WFS&version=1.1.0&request=DescribeFeatureType&outputFormat=application/json&TYPENAME=ngs:country_boundaries,ngs:land_polygons_simp
Response:
{"elementFormDefault":"qualified","targetNamespace":"http://newmoyergeospatial.com","targetPrefix":"ngs","featureTypes":[{"typeName":"country_boundaries","properties":[{"name":"gid","maxOccurs":1,"minOccurs":1,"nillable":false,"type":"xsd:int","localType":"int"},{"name":"geom","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"gml:MultiPolygon","localType":"MultiPolygon"},{"name":"scalerank","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:int","localType":"int"},{"name":"featurecla","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"labelrank","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:number","localType":"number"},{"name":"sovereignt","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"sov_a3","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"adm0_dif","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:number","localType":"number"},{"name":"level","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:number","localType":"number"},{"name":"type","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"admin","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"adm0_a3","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"geou_dif","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:number","localType":"number"},{"name":"geounit","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"gu_a3","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"su_dif","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:number","localType":"number"},{"name":"subunit","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"su_a3","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"brk_diff","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:number","localType":"number"},{"name":"name","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"name_long","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"brk_a3","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"brk_name","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"brk_group","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"abbrev","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"postal","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"formal_en","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"formal_fr","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"note_adm0","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"note_brk","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"name_sort","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"name_alt","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"mapcolor7","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:number","localType":"number"},{"name":"mapcolor8","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:number","localType":"number"},{"name":"mapcolor9","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:number","localType":"number"},{"name":"mapcolor13","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:number","localType":"number"},{"name":"pop_est","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:number","localType":"number"},{"name":"gdp_md_est","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:number","localType":"number"},{"name":"pop_year","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:number","localType":"number"},{"name":"lastcensus","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:number","localType":"number"},{"name":"gdp_year","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:number","localType":"number"},{"name":"economy","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"income_grp","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"wikipedia","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:number","localType":"number"},{"name":"fips_10","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"iso_a2","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"iso_a3","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"iso_n3","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"un_a3","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"wb_a2","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"wb_a3","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"woe_id","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:number","localType":"number"},{"name":"adm0_a3_is","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"adm0_a3_us","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"adm0_a3_un","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:number","localType":"number"},{"name":"adm0_a3_wb","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:number","localType":"number"},{"name":"continent","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"region_un","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"subregion","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"region_wb","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:string","localType":"string"},{"name":"name_len","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:number","localType":"number"},{"name":"long_len","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:number","localType":"number"},{"name":"abbrev_len","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:number","localType":"number"},{"name":"tiny","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:number","localType":"number"},{"name":"homepart","maxOccurs":1,"minOccurs":0,"nillable":true,"type":"xsd:number","localType":"number"}]},{"typeName":"land_polygons_simp"<?xml version="1.0" encoding="UTF-8"?><ows:ExceptionReport xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:ows="http://www.opengis.net/ows" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.0.0" xsi:schemaLocation="http://www.opengis.net/ows https://10.0.1.64/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd">
<ows:Exception exceptionCode="NoApplicableCode">
<ows:ExceptionText>java.io.IOException: Schema 'land_polygons_simp' does not exist.
Schema 'land_polygons_simp' does not exist.</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
The response’s Content-Type header is application/json, however this response will not parse with a JSON decoder.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100201-sha1:92d0e2d)
Atlassian logo
