[Geoserver-devel] [JIRA] (GEOS-10616) WFS exception report (code=NoApplicableCode text=java.lang.RuntimeException: java.lang.RuntimeException: java.io.IOException
Jens Eger - Softec created an issue
GeoServer / BugGEOS-10616
Issue Type:
BugBug
Affects Versions:
2.21.0
Assignee:
Unassigned
geoserver.log
Created:
11/Aug/22 7:47 AM
Environment:
GeoServer 2.21.0 runs in Tomcat9 on Windows Server 20212 R2. All the Layers are coming from a MS SQL (2016) data store.
Priority:
MediumMedium
Reporter:
Jens Eger - Softec
Our customers are exporting all Geometry DataSets from our database to their database. One of our customers sent me an error which I investigated. The customer tried to get via WFS more than 200k objects, which seemed to be no problem in the past. Nowadays we get an error in the resulting wfs.xml from the webservice Call:
2022-08-10T15:47:07 WARNING WFS exception report (code=NoApplicableCode text=java.lang.RuntimeException: java.lang.RuntimeException: java.io.IOException
java.io.IOExceptionAttempt to read past end of input)
I have attached the geoserver logfile for further investigation.
I have checked all the Geometries and additional fields for validity and all ~200k objects are 100% valid. The Error occurs only, when I request a very large amount of data. requesting 1k or 10k objects is not a problem here.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100204-sha1:f3df60f)
Atlassian logo
