When I try to run a WPS process for clipping a WCS raster data with a GeoJSON data it fails to complete the job. But when I do the same with WKT string as a input it completes successfully.
Failed WPS process with JSON input
<?xml version="1.0" encoding="UTF-8"?><wps:Execute version="1.0.0" service="WPS" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.opengis.net/wps/1.0.0" xmlns:wfs="http://www.opengis.net/wfs" xmlns:wps="http://www.opengis.net/wps/1.0.0" xmlns:ows="http://www.opengis.net/ows/1.1" xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc" xmlns:wcs="http://www.opengis.net/wcs/1.1.1" xmlns:xlink="http://www.w3.org/1999/xlink" xsi:schemaLocation="http://www.opengis.net/wps/1.0.0 http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd">
<ows:Identifier>ras:CropCoverage</ows:Identifier>
<wps:DataInputs>
<wps:Input>
<ows:Identifier>coverage</ows:Identifier>
<wps:Reference mimeType="image/tiff" xlink:href="http://geoserver/wcs" method="POST">
<wps:Body>
<wcs:GetCoverage service="WCS" version="1.1.1">
<ows:Identifier>nu:NE2_50M_SR</ows:Identifier>
<wcs:DomainSubset>
<ows:BoundingBox crs="http://www.opengis.net/gml/srs/epsg.xml#4326">
<ows:LowerCorner>-180.0 -90.0</ows:LowerCorner>
<ows:UpperCorner>180.0 90.0</ows:UpperCorner>
</ows:BoundingBox>
</wcs:DomainSubset>
<wcs:Output format="image/tiff"/>
</wcs:GetCoverage>
</wps:Body>
</wps:Reference>
</wps:Input>
<wps:Input>
<ows:Identifier>cropShape</ows:Identifier>
<wps:Data>
<wps:ComplexData mimeType="application/json"><![CDATA[
"type": "Polygon",
"coordinates": [
74.332365694231868,
20.348533699212016
74.005883315616018,
18.018636724544315
76.988745047515422,
16.875948399388822
74.332365694231868,
20.348533699212016
</wps:ComplexData>
</wps:Data>
</wps:Input>
</wps:DataInputs>
<wps:ResponseForm>
<wps:RawDataOutput mimeType="image/jpeg">
<ows:Identifier>result</ows:Identifier>
</wps:RawDataOutput>
</wps:ResponseForm>
</wps:Execute>
Geoserver log error message
08 Dec 14:35:12 ERROR [wps.executor] - Process execution failed
org.geoserver.wps.WPSException: Failed to retrieve value for input cropShape
at org.geoserver.wps.executor.LazyInputMap.parseInputs(LazyInputMap.java:97)
at org.geoserver.wps.executor.LazyInputMap.get(LazyInputMap.java:49)
at org.geotools.process.factory.AnnotationDrivenProcessFactory$InvokeMethodProcess.buildProcessArguments(AnnotationDrivenProcessFactory.java:736)
at org.geotools.process.factory.AnnotationDrivenProcessFactory$InvokeMethodProcess.execute(AnnotationDrivenProcessFactory.java:616)
at org.geoserver.wps.executor.ProcessStartupFilter$ProcessStartupWrapper.execute(ProcessStartupFilter.java:50)
at org.geoserver.wps.executor.DefaultProcessManager$ProcessCallable.call(DefaultProcessManager.java:224)
at org.geoserver.wps.executor.DefaultProcessManager$ProcessCallable.call(DefaultProcessManager.java:192)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:834)
Caused by: java.lang.RuntimeException: java.lang.NoSuchMethodException: org.geotools.geojson.feature.FeatureHandler.<init>(org.locationtech.jts.geom.GeometryFactory)
at org.geotools.geojson.DelegatingHandler.createDelegate(DelegatingHandler.java:125)
at org.geotools.geojson.geom.GeometryHandler.primitive(GeometryHandler.java:58)
at org.json.simple.parser.JSONParser.parse(JSONParser.java:428)
at org.json.simple.parser.JSONParser.parse(JSONParser.java:312)
at org.geotools.geojson.GeoJSONUtil.parse(GeoJSONUtil.java:278)
at org.geotools.geojson.geom.GeometryJSON.parse(GeometryJSON.java:623)
at org.geotools.geojson.geom.GeometryJSON.read(GeometryJSON.java:181)
at org.geoserver.wps.ppio.GeoJSONPPIO$Geometries.decode(GeoJSONPPIO.java:104)
at org.geoserver.wps.ppio.CDataPPIO.decode(CDataPPIO.java:21)
at org.geoserver.wps.executor.SimpleInputProvider.getValueInternal(SimpleInputProvider.java:81)
at org.geoserver.wps.executor.AbstractInputProvider.getValue(AbstractInputProvider.java:100)
at org.geoserver.wps.executor.ValidatingInputProvider.getValue(ValidatingInputProvider.java:39)
at org.geoserver.wps.executor.LazyInputMap.parseInputs(LazyInputMap.java:89)
... 10 more
Caused by: java.lang.NoSuchMethodException: org.geotools.geojson.feature.FeatureHandler.<init>(org.locationtech.jts.geom.GeometryFactory)
at java.base/java.lang.Class.getConstructor0(Class.java:3349)
at java.base/java.lang.Class.getConstructor(Class.java:2151)
at org.geotools.geojson.DelegatingHandler.createDelegate(DelegatingHandler.java:119)
... 22 more
This issue is not seen in GeoServer 2.18.0 when I tested it.
