Mitchell Bösecke created an issue |
WMTS GetCapabilities from Geoserver provides WebMercatorGrid MatrixSet with wrong axis order |
Issue Type: |
Affects Versions: |
2.22.0 |
Assignee: |
Unassigned |
Components: |
GWC, WMTS |
Created: |
21/Mar/23 11:32 PM |
Environment: |
Geoserver 2.22.0 deployed to Wildfly using integrated GWC |
Priority: |
Reporter: |
In Geoserver, I’m fetching a WMTS capabilities document and the built-in WebMercatorGrid matrix set seems to have the axis order in northing/easting, but my understanding is that EPSG:3857 is defined by EPSG as having an axis order of easting/northing.
Here is the relevant section of the XML returned by Geoserver:
<TileMatrixSet>
<ows:Identifier>WebMercatorQuad</ows:Identifier>
<ows:SupportedCRS>urn:ogc:def:crs:EPSG::3857</ows:SupportedCRS>
<TileMatrix>
<ows:Identifier>0</ows:Identifier>
<ScaleDenominator>5.59082264028717E8</ScaleDenominator>
<TopLeftCorner>2.003750834E7 -2.003750834E7</TopLeftCorner>
<TileWidth>256</TileWidth>
<TileHeight>256</TileHeight>
<MatrixWidth>1</MatrixWidth>
<MatrixHeight>1</MatrixHeight>
</TileMatrix>
</TileMatrixSet>
The top left corner is shown as “2.003750834E7 -2.003750834E7” but I believe it should be reversed.
This is causing problems with OpenLayers as a client (layer doesn’t show up at all). The client should be intelligent enough to detect projects with reversed axis orders but I don’t think EPSG:3857 is supposed to have a reversed axis order? Looking at the official spec for the WebMercatorQuad tile matrix set lists the top left corner as -20037508.3427892 20037508.3427892. This is expected and differs from the order I get from Geoserver.
If I switch to the legacy “EPSG:900913” matrix set provided by Geoserver, everything works as expected.
Is this a bug in Geoserver or am I misunderstanding something?
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100218-sha1:518c67a) |
