[Geoserver-devel] [JIRA] (GEOS-10945) Offset between WMS and WMTS after reprojection from 31466 to 3857
Carsten Lockenkötter created an issue
GeoServer / BugGEOS-10945
Issue Type:
BugBug
Affects Versions:
2.21.1, 2.22.2
Assignee:
Unassigned
Components:
WMS, WMTS
Created:
19/Apr/23 10:55 AM
Environment:
Windows Server 2019 Standard (1809)
Apache Tomcat/9.0.62
GeoServer 2.22.2 and 2.21.1
Priority:
MediumMedium
Reporter:
I noticed an offset of about 20cm when serving the ImageMosaic data as WMS and WMTS.
The raster file is in EPSG:31466 on the file system.
When publishing the ImageMosaic, the native coordinate system was correctly set to EPSG:31466.
Declared SRS: EPSG:3857
SRS handling: Reproject native to declared
Everything else was left at default settings. In the “Tile Caching” tab, only the GridSet EPSG:3857 was added, which is a completely identical copy of EPSG:900913.
I have attached two zip files, one containing my complete workspace from GeoServer and another containing an example raster tile.
If I add the layer as WMS and WMTS in QGIS, the offset of about 20cm is clearly visible (see screenshot).
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100222-sha1:cb3bdf0)
Atlassian logo
