Benjamin Mikkelsen created an issue |
GetLegendGraphics with WMS Cascading doesn’t use authentication |
Issue Type: |
Affects Versions: |
2.23.0 |
Assignee: |
Unassigned |
Components: |
WMS |
Created: |
11/May/23 10:43 AM |
Priority: |
Reporter: |
Hello, I’m experiencing an issue with GeoServer 2.23 while using WMS Cascading to fetch some layers from 3rd party sources. Some of these sources require Basic Authentication, while others don’t. Although adding a WMS store with Basic Authentication works for most request-types, it only doesn’t for the GetLegendGraphics endpoint. When I call the GetLegendGraphics endpoint, I receive a blank 1x1 pixel with HTTP Code 200. After investigating the issue, it appears that GeoServer is not sending the Authorization-header for the GetLegendGraphics-request. I contacted the provider of the external GeoServer, who confirmed that the header is missing for the GetLegendGraphics-requests. Here are the steps to reproduce the issue: Create a GeoServer (version 2.23.0) I believe the root cause of this issue is the missing Authorization-header for the GetLegendGraphics-request, which is resulting in a blank 1x1 pixel. The expected behavior would be that the Authorization-header is send. The header correctly send to the GetCapabilities, GetMap and GetFeatureInfo requests. I would appreciate it if you could investigate this issue and provide a fix as soon as possible. Thank you. |
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100225-sha1:84d3b45) |
