Using a REST API script using a weakly typed language the difference between a string and an int resulted in a coverage.xml POST with following invalid ReferencedEnvelope crs:
<crs>0</crs>
In GeoServer 2.21.4 this was preserved:
<coverage>
<name>ijssel_2017_dsm_5</name>
<title>ijssel_2017_dsm_5</title>
<nativeCRS class="projected">...</nativeCRS>
<srs>EPSG:28992</srs>
<projectionPolicy>FORCE_DECLARED</projectionPolicy>
<nativeBoundingBox>
<minx>180000</minx>
<miny>437500</miny>
<maxx>215000</maxx>
<maxy>512500</maxy>
<crs>0</crs>
</nativeBoundingBox>
<latLonBoundingBox>
<minx>5.7511379908659</minx>
<miny>51.9236999711892</miny>
<maxx>6.27331655234198</maxx>
<maxy>52.6005228787716</maxy>
<crs>0</crs>
</latLonBoundingBox>
In newer releases (GeoServer 2.24.x and 2.23.0, … GeoServer 2.22.2?) the ReferencedEnvelopes having no crs:
<nativeBoundingBox>
<minx>180000</minx>
<miny>437500</miny>
<maxx>215000</maxx>
<maxy>512500</maxy>
<latLonBoundingBox>
While this does not look like a significant change … select WCS operations have trouble:
- WCS 1.0.x DescribeCoverage is fine
- WCS 1.1.x DescribeCoverage has a translate error
- WCS 2.0.x DescribeCoverage has a translate error
java.lang.NullPointerException: Cannot invoke "org.opengis.referencing.crs.CoordinateReferenceSystem.getCoordinateSystem()" because "crs" is null
javax.xml.transform.TransformerException: Translator error
Translator error
Unexpected error occurred during describe coverage xml encoding
I can only assume that some WCS code paths are ignoring the coverage.xml <srs>EPSG:28992</srs> setting and trusting the native information to be correct and available.
