[Geoserver-devel] [jira] (GEOS-4934) not able to query wms getFeatureInfo with layername derived by sld
Hajo Kliemeck created GEOS-4934:
             Summary: not able to query wms getFeatureInfo with layername derived by sld
                 Key: GEOS-4934
                 URL: https://jira.codehaus.org/browse/GEOS-4934
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 2.1.3
            Reporter: Hajo Kliemeck
            Assignee: Andrea Aime
         Attachments: featureinfo-with-sld.patch
If you are requesting your map with a sld document, which contains the layernames, you are unable to query the layer for getFeatureInfo. if LAYERS/QUERY_LAYERS is not set, the layernames should be derived by the sld document.
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
