[Geoserver-devel] [jira] (GEOS-4951) WFS request with OGC filter subtracts time zone offset from database date_time - GML output only
Andrew Walsh created GEOS-4951:
             Summary: WFS request with OGC filter subtracts time zone offset from database date_time - GML output only
                 Key: GEOS-4951
                 URL: https://jira.codehaus.org/browse/GEOS-4951
             Project: GeoServer
          Issue Type: Bug
          Components: WFS
    Affects Versions: 2.1.3
         Environment: Geoserver 2.1.3 with Geotools 2.7.4, Windows XP/Jetty, ARCSDE datastore with ESRI 9.3 SDK jars
            Reporter: Andrew Walsh
            Assignee: Andrea Aime
             Fix For: 2.1.4
Adding an OGC filter to a WFS request say filter by LOCATION='Bilgola' causes
subraction/addition of the local server time zone offset in GML output apparently to convert
back to UTC. For example in the Oracle SDE table OBS_DATE_TIME=2004-11-14 11:37:00
(its a simple ORACLE DATE type in format YYYY-MM-DD hh:mm:ss)
but on output to GML 11 hours is subtracted (we are now in zone GMT+11 Australian EST (10) + Daylight Saving (1))
to OBS_DATE_TIME=2004-11-14 00:37:00. Not good for us -:frowning: as for scientific data
we don't wan't to mislead/confuse clients about observation time.
Example request:
http://localhost:8080/geoserver/wfs?&VERSION=1.1.0&SERVICE=WFS&REQUEST=GetFeature&TYPENAME=test:RAN.BEACH_TEMP&Filter=<Filter><PropertyIsEqualTo><PropertyName>LOCATION</PropertyName><Literal>Bilgola</Literal></PropertyIsEqualTo></Filter>
GML you get back in browser:
<wfs:FeatureCollection numberOfFeatures="3" timeStamp="2012-02-07T06:13:55.734Z" .........">
  <gml:featureMembers>
    <test:RAN.BEACH_TEMP gml:id="RAN.BEACH_TEMP.10638">
      <test:LON>151.3282</test:LON>
      <test:LAT>-33.646</test:LAT>
      <test:META_UUID>2d96ee5a-bc79-4d29-b627-f09f81f9e163</test:META_UUID>
      <test:LOC_ID>5.0</test:LOC_ID>
      <test:LOCATION>Bilgola</test:LOCATION>
      <test:OBS_DATE_TIME>2004-11-14T00:37:00.593Z</test:OBS_DATE_TIME>
      <test:TZONE>+11:00</test:TZONE>
      <test:SST>19.3</test:SST>
      <test:SHAPE>
        <gml:Point srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4326">
          <gml:pos>-33.646000000000015 151.32820000000004</gml:pos>
        </gml:Point>
      </test:SHAPE>
    </test:RAN.BEACH_TEMP>
  </gml:featureMembers>
</wfs:FeatureCollection>
Feature RAN.BEACH_TEMP.10638 has date_time 2004-11-14 11:37:00 in Oracle db
but on output to GML reports 2004-11-14T00:37:00.593Z. That is 11 hours
has been subtracted and its assuming that its a UTC time with the 'Z'
suffix. This is confusing and could be wrong as Geoserver is making assumption
about the time zone the observations were done in.
I note also the same request with CSV output issue doesn't happen i.e:
http://localhost:8080/geoserver/wfs?&VERSION=1.1.0&SERVICE=WFS&REQUEST=GetFeature&TYPENAME=test:RAN.BEACH_TEMP&Filter=&lt;Filter&gt;&lt;PropertyIsEqualTo&gt;&lt;PropertyName&gt;LOCATION&lt;/PropertyName&gt;&lt;Literal&gt;Bilgola&lt;/Literal&gt;&lt;/PropertyIsEqualTo&gt;&lt;/Filter&gt;&amp;outputFormat=csv
Note also if you just request all features in layer with NO filter
the date_time is unchanged.
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
