[Geoserver-devel] [jira] (GEOS-4986) Creating SQL Views via RESTConfig as JSON fails
Robert Coup created GEOS-4986:
             Summary: Creating SQL Views via RESTConfig as JSON fails
                 Key: GEOS-4986
                 URL: https://jira.codehaus.org/browse/GEOS-4986
             Project: GeoServer
          Issue Type: Bug
          Components: REST
    Affects Versions: 2.1.3
            Reporter: Robert Coup
            Assignee: Andrea Aime
Goal: Create a SQL View via REST config, using the JSON API format.
Problem: {{org.geoserver.config.util.XStreamPersister.VirtualTableConverter.unmarshal()}} parses the JSON for the virtual-table declaration in the POST in a sequence-specific way. This is fine for XML, but the equivalent JSON uses an object, which is meant to be _unordered_ as per the [JSON RFC|http://www.ietf.org/rfc/rfc4627\]. Depending on the language/library generating the JSON, it can be really hard to get it in a defined order (and it's not obvious that's the problem... errors are about missing keys).
Example:
POST to: {{http://localhost:8080/geoserver/rest/workspaces/my/datastores/my_database/featuretypes.json\}}
Not working:
{code:javascript}
    "featureType": {
        "metadata": {
            "entry": [
                    "@key": "JDBC_VIRTUAL_TABLE",
                    "virtualTable": {
                        "geometry": {
                            "type": "Polygon",
                            "name": "my_geometry",
                            "srid": 5479
                        "keyColumn": "my_pk",
                        "parameter": [
                                "regexpValidator": "^[\\w\\d\\s]+$",
                                "name": "from"
                                "name": "to"
                        "name": "foo",
                        "sql": "SELECT * FROM foo WHERE my_field BETWEEM %from% AND %to%"
{code}
Working (magic sequence order):
{code:javascript}
    "featureType": {
        "metadata": {
            "entry": [
                    "virtualTable": {
                        "name": "foo",
                        "sql": "SELECT * FROM foo WHERE my_field BETWEEM %from% AND %to%",
                        "geometry": {
                            "type": "Polygon",
                            "srid": 5479
                        "parameter": [
                                "name": "from",
                                "name": "to",
{code}
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
