[Geoserver-devel] [jira] (GEOS-4993) Make GWC "direct WMS integration" work with virtual services
Gabriel Roldán created GEOS-4993:
             Summary: Make GWC "direct WMS integration" work with virtual services
                 Key: GEOS-4993
                 URL: https://jira.codehaus.org/browse/GEOS-4993
             Project: GeoServer
          Issue Type: New Feature
          Components: GWC
            Reporter: Gabriel Roldán
            Assignee: Gabriel Roldán
             Fix For: 2.2.x
When virtual services were introduced, gwc integration wasn't updated accordingly, hence tilesets are only contributed to the wms capabilities document if using the root wms service, but if using a virtual service path (e.g. http://localhost:8080/geoserver/topp/wms?…) no tile sets are contributed.
Make it so that layers from the virtual service workspace are contributed to the virtual service capabilities document, and in a way that follows the same rules re "harmonized layer names".
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
