Niels Charlier created GEOS-5080:
Summary: app-schema wms does not support reprojection and fails after wfs request
Key: GEOS-5080
URL: https://jira.codehaus.org/browse/GEOS-5080
Project: GeoServer
Issue Type: Bug
Components: Application schema
Reporter: Niels Charlier
Assignee: Niels Charlier
This issue covers two problems:
* app-schema wms does not support reprojection
* When making a testing, noticed that after making a successful request for an open layer for WMS base on complex feature, follow with a WFS request to the same complex feature, the consequence request to the WMS request will fail.
These two issues are grouped because they are related, running wms after wfs causes reprojection to occur even if it hasn't been put in the request. The failure of running wms after wfs is caused by the failure of reprojection combined with wfs leaving reprojection stuff behind in static data
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
