[Geoserver-devel] [jira] (GEOS-5089) Document admin access mode
Justin Deoliveira created GEOS-5089:
             Summary: Document admin access mode
                 Key: GEOS-5089
                 URL: https://jira.codehaus.org/browse/GEOS-5089
             Project: GeoServer
          Issue Type: Task
          Components: Security
            Reporter: Justin Deoliveira
            Assignee: Justin Deoliveira
Users upgrading to 2.2 will run into problem if they have opened up the rest api to be accessed anonymously or by the non-admin user. Now with the admin access mode the default is to provide admin privileges only to role administrator. The upshot is that the user will no longer see any workspaces because they don't have admin privileges on them any longer.
This should be clearly documented for those upgrading to 2.2.
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
