[Geoserver-devel] [jira] (GEOS-5115) Print Problem
girish created GEOS-5115:
             Summary: Print Problem
                 Key: GEOS-5115
                 URL: https://jira.codehaus.org/browse/GEOS-5115
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.1.1
            Reporter: girish
            Assignee: Andrea Aime
I've been working with print extent plugin and print mappanel from quiet long.... I tried the example http://api.geoext.org/1.1/examples/pr… , it worked fine, until i replaced the layers with that of mine..... printing of map works fine.... but printing of a particular extent doesn't seem to work!....i tried replacing the layer with tasmania state boundaries that was there in my geoserver ... printing of zoomed extent worked perfect then !... is there some projection system problem ?... because the layer i tried to work with when the print zoomed extent did not work was in the projection system 32645.....
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
