Bernhard Kamps created |
Issue Type: |
Affects Versions: |
2.1.4, 2.1.3 |
Assignee: |
Components: |
SQLServer |
Created: |
18/Jun/12 4:20 PM |
Description: |
I have used FME to upload an autocad drawing to SQL Server 2012 Spatial. When I connect to the SQL Server 2012 from Geoserver I am able to see the appropriate layers. When I try to publish a layer, I must select a Declared CRS. Since a CRS is not provided in the source data, I select one from the Geoserver dialog. Then, when I click the Compute From Data I get the following error at the bottom of the stacktrace: No code “EPSG:0” from authority “European Petroleum Survey Group” found for object of type “IdentifiedObject”. I could provide the entire stacktrace if it would be helpful. I validated that the geometry field in the sql server db is valid. Thanks, |
Environment: |
Windows 7, SQL Server 2012 Spatial, Geoserver 2.1.4/2.1.3 |
Fix Versions: |
2.1.x |
Project: |
Priority: |
Reporter: |
