[Geoserver-devel] [jira] (GEOS-5257) Intermittent build failure in main XMLUserGroupServiceTest
Ben Caradoc-Davies created BugGEOS-5257
Issue Type:
BugBug
Affects Versions:
2.3-beta1
Assignee:
Andrea Aime
org.geoserver.security.xml.XMLSecurityConfigValidatorTest.txt, org.geoserver.security.xml.XMLUserGroupServiceTest.txt
Components:
Global
Created:
07/Aug/12 8:51 PM
Description:
Build fails intermittently in main with:
Failed tests:   testIsModified(org.geoserver.security.xml.XMLUserGroupServiceTest)
  testEmptyPassword(org.geoserver.security.xml.XMLUserGroupServiceTest): expected:<0> but was:<6>
Tests in error:
  testEraseCredentials(org.geoserver.security.xml.XMLUserGroupServiceTest): Already locked
  testPasswordRecoding(org.geoserver.security.xml.XMLUserGroupServiceTest): Already locked
  testRoleConfig(org.geoserver.security.xml.XMLSecurityConfigValidatorTest): org.geoserver.data.test.LiveData cannot be cast to org.geoserver.data.test.MockData
Surefire reports attached.
Environment:
Apache Maven 3.0.4 (r1232337; 2012-01-17 16:44:56+0800)
Maven home: /home/car605/junk/java/maven3
Java version: 1.6.0_32, vendor: Sun Microsystems Inc.
Java home: /home/car605/junk/java/jdk1.6.0_32.x64/jre
Default locale: en_GB, platform encoding: UTF-8
OS name: “linux”, version: “2.6.43.8-1.fc15.x86_64”, arch: “amd64”, family: “unix”
Project:
Priority:
MajorMajor
Reporter:
Ben Caradoc-Davies
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
