[Geoserver-devel] [jira] (GEOS-5319) WFS-T insert of MultiPolygon exception with logging at VERBOSE
albert valls created BugGEOS-5319
Issue Type:
BugBug
Affects Versions:
2.1.4, 2.1.1
Assignee:
Andrea Aime
logtrace.txt
Components:
Oracle, WFS
Created:
21/Sep/12 3:33 AM
Description:
We are using WFS-T to edit a table with a geometry of type MultiPolygon. When the debug level of the geoserver is set to PRODUCTION or DEFAULT everything works great.
If we set the debug to VERBOSE the inserts or edits fail when using a multipolygon with more than one feature (with a multipolygon of 1 element works fine).
The attached file contains the exception trace.
If you need further details, please ask.
Environment:
Tested on windows with geoserver 2.1.4 on Tomcat. Using an Oracle datastore.
Project:
Labels:
exception
Priority:
MajorMajor
Reporter:
albert valls
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
