Date: Tue, 16 Oct 2012 20:05:39 -0600
Subject: Re: [Geoserver-devel] [jira] (GEOS-5332) KMLTransformer does
not include sld and vendor parameters into the request
To: ccancellieri@anonymised.com
CC: geoserver-devel@lists.sourceforge.net
Hi Carlo,
Sorry for the confusion. Allow me to reiterate.
I agree that against the normal wms service endpoint that these options
should be specified as format options. So I agree that:
geoserver/wms?legend=true&...
Should be:
geoserver/wms?format_options=legend:true&...
And i agree the documentation should reflect that.
However, when going against the kml endpoint the options may be
specified directly. So I see this as still valid:
/geoserver/wms/kml?legend=true
So, with regard to your proposed changes.
- remove deprecated use of getLegend from KMLTransformer.encode()
method using the format_options
Agreed.
- fix documentation porting deprecated (and not used getters) options
under the format_options section.
For the normal wms endpoint:
http://docs.geoserver.org/latest/en/user/services/wms/vendor.html)
Yes I agree the docs should updated. But for the kml specific reflector
endpoint:
http://docs.geoserver.org/latest/en/user/googleearth/features/kmlreflector.html
I think the options are valid when specified directly and should be
left as is.
- align the GEOS-5332 fix to the new changes.
Sounds good.
Hope that clears it up.
-Justin
On Tue, Oct 16, 2012 at 8:17 AM, Carlo Cancellieri
<ccancellieri@anonymised.com<mailto:ccancellieri@anonymised.com>> wrote:
Hi Justin,
I'm looking at the code...
> From a pure WMS request standpoint the format options are the correct
> way. But the kml reflector is meant purely for convenience, so using
> the parameters as kvp in the request makes sense. So i would say that
> having the KML reflector (or some other reflector) support direct
> options and translate them into the format_options parameter for the
> reflecting request it is generated is ok. Does that make sense?
It may cause some confusion in users and add unnecessary logic on my
point of View.
I see that most of the methods for the kvp parameters are deprecated
into the WMSGetMapRequest saying:
@deprecated use <code>getFormatOptions().get( "legend" )</code>
All of those methods are unused except than getLegend() used into
the KMLTransformer.encode() method.
Do you think that we have to continue supporting those options as kvp?
My intention was to:
If this is not the case and you think that we have to continue
supporting those deprecated options,
the parameters specified in format_options may override those specified
as kvp mode?
If is this the case, can these changes be backported to the 2.2.1 release ?
Sorry but I want to close this issue ASAP (in the best way).
Thank you,
Carlo
> On Tue, Oct 16, 2012 at 7:00 AM, Carlo Cancellieri
<ccancellieri@anonymised.com<mailto:ccancellieri@anonymised.com><mailto:ccancellieri@…21…<mailto:ccancellieri@anonymised.com>>>
wrote:
> Hi all,
> I'm going to complete this fix but I'm in doubt on how to use some
> vendor parameters:
> Looking here:
> I see that KMSCORE and KMATTR may be specified as normal parameters
> &Kmscore=100&kmattr=...
> The kml reflector instead uses those parameters into format_options:
<href><![CDATA[http://hqlprtcdrgeo2.hq.un.fao.org:8082/geoserver/wms?height=1024&width=1024&layers=AQUASTAT:globcover&request=GetMap&service=wms&styles=aquastat_globcover&format_options=SUPEROVERLAY:false;KMPLACEMARK:false;KMSCORE:40;KMATTR:true;&srs=EPSG:4326&format=application/vnd.google-earth.kmz&transparent=false&version=1.1.1<http://hqlprtcdrgeo2.hq.un.fao.org:8082/geoserver/wms?height=1024&width=1024&layers=AQUASTAT:globcover&request=GetMap&service=wms&styles=aquastat_globcover&format_options=SUPEROVERLAY:false%3BKMPLACEMARK:false%3BKMSCORE:40%3BKMATTR:true%3B&srs=EPSG:4326&format=application/vnd.google-earth.kmz&transparent=false&version=1.1.1>\]<http://hqlprtcdrgeo2.hq.un.fao.org:8082/geoserver/wms?height=1024&width=1024&layers=AQUASTAT:globcover&request=GetMap&service=wms&styles=aquastat_globcover&format_options=SUPEROVERLAY:false%3BKMPLACEMARK:false%3BKMSCORE:40%3BKMATTR:true%3B&srs=EPSG:4326&format=application/vnd.google-earth.kmz&transparent=false&version=1.1.1]>\]></href>
> What's the correct way? Are there any other vendor parameters which
> should be moved under format_options? (so I could fix documentation).
> Thank you,
> Carlo
> ________________________________
> > Date: Wed, 3 Oct 2012 11:32:36 -0500
> > From:
jira@anonymised.com<mailto:jira@anonymised.com><mailto:jira@anonymised.com..121...>>
> > To:
geoserver-devel@lists.sourceforge.net<mailto:geoserver-devel@anonymised.comforge.net><mailto:geoserver-devel@lists.sourceforge.net>
> > Subject: [Geoserver-devel] [jira] (GEOS-5332) KMLTransformer does not
[https://dub108.mail.live.com/Handlers/ImageProxy.mvc?bicild=&canary=uHsGiqJpKLnc5WM1imT0qjuhVtjpAGexKr%2FTscmysv4%3D0&url=http%3A%2F%2Fwww.codehaus.org%2Fcodehaus-small.gif<https://dub108.mail.live.com/Handlers/ImageProxy.mvc?bicild=&canary=uHsGiqJpKLnc5WM1imT0qjuhVtjpAGexKr/Tscmysv4%3D0&url=http://www.codehaus.org/codehaus-small.gif><https://dub108.mail.live.com/Handlers/ImageProxy.mvc?bicild=&canary=uHsGiqJpKLnc5WM1imT0qjuhVtjpAGexKr/Tscmysv4%3D0&url=http://www.codehaus.org/codehaus-small.gif>\]
> > [https://jira.codehaus.org/secure/useravatar?avatarId=10232]
> > carlo
cancellieri<https://jira.codehaus.org/secure/ViewProfile.jspa?name=ccancellieri>
> > created [Bug] GEOS-5332<https://jira.codehaus.org/browse/GEOS-5332>
> > KMLTransformer does not include sld and vendor parameters into the
> > request<https://jira.codehaus.org/browse/GEOS-5332>
> > Issue Type: [Bug] Bug
> > Affects Versions: 2.2.x, 2.3-beta1
> > Assignee: Andrea
> > Aime<https://jira.codehaus.org/secure/ViewProfile.jspa?name=aaime>
> > Created: 03/Oct/12 11:31 AM
> > Description:
> > when using a request like the following:
> > http://localhost:8080/geoserver/ows?
> > service=WMS&request=getMap&version=1.1.1
> > &layers=sf:7416_eto01
> > &cql_filter=gaez_id='lr_soi_hwsd_domi'
> > &bbox=-180,-90,180,90
> > &width=256&height=256&transparent=true
> > &sld=http://gaez.fao.org/getSLD?id=pixGAEZtiffhwsddomi036136
> > &srs=EPSG:4326
> > &format=application/vnd.google-earth.kml+xml
> > I obtain a kml without the sld into the wms request, this also happens
> > for some of the vendor parameters.
> > Fix Versions: 2.2.1
> > Project: GeoServer<https://jira.codehaus.org/browse/GEOS>
> > Priority: [Major] Major
> > Reporter: carlo
> > This message is automatically generated by JIRA.
> > If you think it was sent incorrectly, please contact your JIRA
administrators<https://jira.codehaus.org/secure/ContactAdministrators!default.jspa>\.
> > For more information on JIRA, see: http://www.atlassian.com/software/jira
Justin Deoliveira
OpenGeo - http://opengeo.org
