[Geoserver-devel] [jira] (GEOS-5390) Cascading WMS changing workspace results in exceptions
Eric Kangas created BugGEOS-5390
Issue Type:
BugBug
Affects Versions:
2.2.1, 2.2
Assignee:
Andrea Aime
cascading wms workspace exception.txt, wms (46)
Components:
Wicket UI, WMS
Created:
02/Nov/12 4:08 PM
Description:
Tried to change the workspace of an external cascaded WMS, which resulted in exceptions.
Have a working Cascading WMS set up:
Here is USGS NAIP, which I was using.
http://isse.cr.usgs.gov/ArcGIS/services/Orthoimagery/SDDS_Imagery/MapServer/WMSServer
Then try to change the workspace from the web UI to any other, and view the layer results in an exception.
Also, the layer does not show up when trying to preview or use it.
Environment:
Windows 7 64 bit, Tomcat in Eclipse
Project:
Priority:
MajorMajor
Reporter:
Eric Kangas
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
