Evan Martin created GEOS-5567 |
Issue Type: |
Bug |
Affects Versions: |
2.2.2 |
Assignee: |
Components: |
WMS |
Created: |
15/Jan/13 11:23 PM |
Description: |
When I make a WMS request that causes an exception the exception is always returned in XML format, regardless of what I specify in the “exceptions” parameter. Eg. if I specify a layer name that doesn’t exist: The response I get is: <?xml version=“1.0” encoding=“UTF-8” standalone=“no”?><!DOCTYPE ServiceExceptionReport SYSTEM “http://localhost:8080/geoserver/schemas/wms/1.1.1/WMS_exception_1_1_1.dtd”> <ServiceExceptionReport version=“1.1.1” > <ServiceException code=“LayerNotDefined”> Based on the documentation I expect an image to be returned. The same happens no matter what I try as the “exceptions” value. |
Environment: |
Windows 7 x64, JVM 1.6.0_31 |
Project: |
Priority: |
Major |
Reporter: |
