[Geoserver-devel] [jira] (GEOS-5568) Use Transifex as translation tool
Oscar Fonts created New FeatureGEOS-5568
Issue Type:
New FeatureNew Feature
Affects Versions:
2.3-beta1
Assignee:
Andrea Aime
Created:
16/Jan/13 5:44 AM
Description:
Frank Gasdorf and Oscar Fonts are working on how to integrate Transifex as the translation tool for geoserver.
Working on the GitHub branch:
https://github.com/fgdrf/geoserver/tree/gs-transifex
Using the transifex project:
https://www.transifex.com/projects/p/geoserver_23x/
Subtasks:
  1. [Oscar] Make sure translated texts are correctly encoded in all running scenarios (within eclipse; through mvn jetty:run; on released war).
  2. [Frank] Discern “draft” vs. “reviewed” translations. Transifex provides mechanisms to do so. Incorporate to build only the reviewed ones.
  3. [Frank] Pull resources from transifex as a mvn action, so they can be easily incorporated in the build/release processes.
  4. [?] Add a language selector to the web interface that overrides actual behavior (now, language is chosen from browser preferences).
  5. [Oscar] Docs: Update guide for translators and for release building.
Environment:
All
Project:
Priority:
MajorMajor
Reporter:
Oscar Fonts
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
