[Geoserver-devel] [jira] (GEOS-5604) REST workspaces/default.(json|xml) can't be PUT back in the same format they arrived in
Benjamin Trigona-Harany created BugGEOS-5604
REST workspaces/default.(json|xml) can’t be PUT back in the same format they arrived in
Issue Type:
BugBug
Affects Versions:
2.3-beta1
Assignee:
Andrea Aime
Components:
REST
Created:
25/Jan/13 5:28 PM
Description:
The results of workspaces/default.json and workspaces/default.xml can’t be PUT back as they arrived.
XML:
<workspace>
  <name>sf</name>
  <dataStores>
    <atom:link xmlns:atom="http://www.w3.org/2005/Atom" rel="alternate" href="http://localhost:8080/geoserver-2.3-beta1/rest/workspaces/default/datastores.xml" type="application/xml"/>
  </dataStores>
  <coverageStores>
    <atom:link xmlns:atom="http://www.w3.org/2005/Atom" rel="alternate" href="http://localhost:8080/geoserver-2.3-beta1/rest/workspaces/default/coveragestores.xml" type="application/xml"/>
  </coverageStores>
  <wmsStores>
    <atom:link xmlns:atom="http://www.w3.org/2005/Atom" rel="alternate" href="http://localhost:8080/geoserver-2.3-beta1/rest/workspaces/default/wmsstores.xml" type="application/xml"/>
  </wmsStores>
</workspace>
However, to change the default workspace, the format must be simply:
<workspace>
  <name>sf</name>
</workspace>
Attempting to PUT back the original document gets a:
No such field org.geoserver.catalog.impl.WorkspaceInfoImpl.dataStores
---- Debugging information ----
field               : dataStores
class               : org.geoserver.catalog.impl.WorkspaceInfoImpl
required-type       : org.geoserver.catalog.impl.WorkspaceInfoImpl
converter-type      : org.geoserver.config.util.XStreamPersister$SpaceInfoConverter
line number         : 1
version             : null
* Closing connection #0
Project:
Priority:
MinorMinor
Reporter:
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
