[Geoserver-devel] [jira] (GEOS-5611) Avoid security migration whenever possible
Christian Mueller created ImprovementGEOS-5611
Issue Type:
ImprovementImprovement
Affects Versions:
2.3-beta1
Assignee:
Christian Mueller
Components:
Security
Created:
28/Jan/13 7:52 AM
Description:
There are 2 situations where security migration can be avoided.
  1. A fresh geoserver 2.3.x install. The directory date/release/security has to be prepared. The admin password is geoserver, the master password is geoserver too.
  2. System test setup. The security.zip file is modified and includes the result of
    migration from 2.1->2.2 and 2.2–>2.3
The java keystore file cannot be prepared in advance. Sad but true, it is not possible to open a keystore created with Oracle jdk with an IBM jdk. Keystore creation happens on the fly.
Project:
Priority:
MajorMajor
Reporter:
Christian Mueller
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
