Issue Type:
Bug
Affects Versions:
2.4-beta
Assignee:
Andrea Aime
Components:
WMS
Created:
04/Feb/13 1:55 AM
Description:
On platforms where GetFeatureInfoIntegrationTest testCustomTemplateManyRules runs before testSimpleHtml, testBuffer, testAutoBuffer, or testBufferScales, the latter fail because testCustomTemplateManyRules installs a custom template but fails to remove it.
Test set: org.geoserver.wms.wms_1_3.GetFeatureInfoIntegrationTest
Tests run: 21, Failures: 4, Errors: 0, Skipped: 0, Time elapsed: 2.609 sec <<< FAILURE!
testSimpleHtml(org.geoserver.wms.wms_1_3.GetFeatureInfoIntegrationTest) Time elapsed: 84 sec <<< FAILURE!
junit.framework.ComparisonFailure: expected:<[1]> but was:<[0]>
at junit.framework.Assert.assertEquals(Assert.java:85)
at junit.framework.Assert.assertEquals(Assert.java:91)
at org.custommonkey.xmlunit.XMLAssert.assertXpathEvaluatesTo(XMLAssert.java:858)
at org.geoserver.wms.wms_1_3.GetFeatureInfoIntegrationTest.testSimpleHtml(GetFeatureInfoIntegrationTest.java:265)
testBuffer(org.geoserver.wms.wms_1_3.GetFeatureInfoIntegrationTest) Time elapsed: 93 sec <<< FAILURE!
at org.geoserver.wms.wms_1_3.GetFeatureInfoIntegrationTest.testBuffer(GetFeatureInfoIntegrationTest.java:288)
testAutoBuffer(org.geoserver.wms.wms_1_3.GetFeatureInfoIntegrationTest) Time elapsed: 63 sec <<< FAILURE!
at org.geoserver.wms.wms_1_3.GetFeatureInfoIntegrationTest.testAutoBuffer(GetFeatureInfoIntegrationTest.java:321)
testBufferScales(org.geoserver.wms.wms_1_3.GetFeatureInfoIntegrationTest) Time elapsed: 63 sec <<< FAILURE!
at org.geoserver.wms.wms_1_3.GetFeatureInfoIntegrationTest.testBufferScales(GetFeatureInfoIntegrationTest.java:353)
Environment:
Apache Maven 3.0.4 (r1232337; 2012-01-17 16:44:56+0800)
Maven home: /home/car605/junk/java/maven3
Java version: 1.6.0_37, vendor: Sun Microsystems Inc.
Java home: /home/car605/junk/java/jdk1.6.0_37.x64/jre
Default locale: en_GB, platform encoding: UTF-8
OS name: “linux”, version: “3.7-trunk-amd64”, arch: “amd64”, family: “unix”
Project:
Priority:
Critical
Reporter:
Ben Caradoc-Davies
If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa).
For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
