Micah Wengren created GEOS-5671 |
Issue Type: |
Bug |
Affects Versions: |
2.2.4, 2.2.1, 2.2 |
Assignee: |
Components: |
REST |
Created: |
01/Mar/13 9:01 AM |
Description: |
We’ve been seeing incorrect responses from the REST API when the GeoSearch plugin is deployed in GeoServer 2.2.x. GET requests to any of the following .xml or .json URLs return 404 responses with ‘Layer layers not found’, or ‘Layer workspaces not found’ messages: http://geoserver.example.com/geoserver/rest/workspaces.xml, rest/styles.xml, rest/layers.xml (or equivalent .json representations). Has anyone else observed this? It may take a Tomcat restart in order for this issue to show up, after the initial deploy. Removing the geosearch.jar and restarting Tomcat restores normal behavior. Thanks! |
Environment: |
Debian Linux, Apache Tomcat 6, Java 1.6.0 |
Project: |
Priority: |
Minor |
Reporter: |
