[Geoserver-devel] [jira] (GEOS-5716) Reduce repeated setup need in securty tests
Andrea Aime created BugGEOS-5716
Issue Type:
BugBug
Assignee:
Christian Mueller
Created:
17/Mar/13 4:46 AM
Description:
The following security tests are using repeated setup:
./main/src/test/java/org/geoserver/security/password/MasterPasswordChangeTest.java
./main/src/test/java/org/geoserver/security/validation/RoleStoreValidationWrapperTest.java
./main/src/test/java/org/geoserver/security/auth/AuthenticationFilterTest.java
./main/src/test/java/org/geoserver/security/auth/AuthenticationCacheFilterTest.java
./security/jdbc/src/test/java/org/geoserver/security/jdbc/JDBCConnectAuthProviderTest.java
See if the need for repeated setups can be removed by reverting security configuration changes instead.
Project:
Priority:
MajorMajor
Reporter:
Andrea Aime
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
