[Geoserver-devel] [jira] (GEOS-5770) JSON-GeometryCollection-Bug
Paul Biskup created BugGEOS-5770
Issue Type:
BugBug
Assignee:
Andrea Aime
Created:
15/Apr/13 3:35 AM
Description:
There is a bug in GeoServer when working with GeometryCollections and JSON-output-format in a WFS-GetFeature-request.
see related post in Mailing List:
http://osgeo-org.1560.x6.nabble.com/JSON-output-through-the-WFS-fails-td3786946.html
I could find and fix the problem in my local GeoServer-sourcecode.
Here is the solution:
It is a just a small problem when writing the JSON-Object.
File: GeoJSONBuilder.java
Function: writeGeomCollection (line 109)
In the code when writing a GeometryCollection, first the array gets created and then the key “Geometries” gets written. You have to switch the two lines, and the JSON-Output for GeometryCollection will work fine.
private JSONBuilder writeGeomCollection(GeometryCollection collection) {
//IMPORTANT geometries-key must be written before creating array
this.key(“geometries”);
this.array();
for (int i = 0, n = collection.getNumGeometries(); i < n; i++)
{ writeGeom(collection.getGeometryN(i)); }
return this.endArray();
Project:
Priority:
MajorMajor
Reporter:
Paul Biskup
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
