Joseph Glynn created |
Issue Type: |
Affects Versions: |
2.3.0, 2.2.4 |
Assignee: |
Attachments: |
sf-roads.jpg |
Components: |
GWC |
Created: |
22/Apr/13 11:18 PM |
Description: |
I found an issue in 2.2.4 and it also occurs in 2.3.0. The issue is that when I set the tile cache gutter on a layer, some tiles would display misaligned to adjacent tiles and the erroneous tiles were actually bigger than adjacent tiles. The actual tile image sizes were different. There is an easy way to reproduce this. Here are the steps:
You will see the image displayed is corrupted. I’ve attached a screenshot. Through debugging I believe there is an incorrect conditional in GeoServerMetaTile.writeTileToStream(). The code on line 80 if (this.tiles.length > 1) should be if (this.tiles.length > 0) I made this change locally and it fixes the issue. Please not that this issue can occur on some tiles even if the meta-tiling is more than 1x1 (it happens on my layers for 2x2, 3x3, 4x4 etc.) Using 1x1 just emphasizes the issue for this JIRA. |
Project: |
Priority: |
Reporter: |
Original Estimate: |
4 hours |
Remaining Estimate: |
4 hours |
