[Geoserver-devel] [jira] (GEOS-5814) Restarting geoserver makes teradata not fetch its tables
Hassam Hassam created BugGEOS-5814
Issue Type:
BugBug
Affects Versions:
2.3.1
Assignee:
Andrea Aime
Components:
Querylayer
Created:
16/May/13 12:45 AM
Description:
1.I installed teredata plugin for geoserver
2.made a connection
3. published the layer
4. viewed in Layer Preview.
5.Now when I shutdown geoserver and start it Then,
6.In Edit Layer I get “Failed to load attribute list, internal error is: Schema ‘http://www.opengeospatial.net/cite:PAKISTAN_MAP_REGION’ does not exist.”
7.Then I check the Teradata connection in datastore ,it is connecting but doesnot shows or fetches tables from the database as it does when you setup the connection for the first time.
I have to setup a new datastore everytime I restart geoserver and it works fine.I think it is a bug
Environment:
Windows 7 32-bit,Teradata 14
Project:
Labels:
exception restart teradata tables
Priority:
MajorMajor
Reporter:
Hassam Hassam
Original Estimate:
1 day
Remaining Estimate:
1 day
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
