[Geoserver-devel] [jira] (GEOS-5893) WMS 1.3.0 GetCapabilities only works when logged in
Jonathan Moules created BugGEOS-5893
Issue Type:
BugBug
Affects Versions:
2.3.3
Assignee:
Andrea Aime
Components:
WMS
Created:
18/Jul/13 9:14 AM
Description:
My WMS 1.3.0 GetCapabilities only seems to work when I access it logged in to GeoServer (using the link on the GeoServer “home” page).
I don’t have any security stuff set up yet, though I did twiddle with roles a little a month or two ago.
WMS 1.1.1 GetCapabilities remains identical whether logged in or out as best I can tell.
If I’m not logged in I receive:
<ServiceException>
javax.xml.transform.TransformerException: java.lang.NullPointerException java.lang.NullPointerException null
</ServiceException>
The stacktrace from the logs is:
2013-07-18 14:10:07,652 INFO [org.geoserver.wms] -
Request: getServiceInfo
2013-07-18 14:10:07,653 INFO [org.geoserver.wms] -
Request: getCapabilities
Namespace = null
UpdateSequence = null
Version = 1.3.0
Request = GetCapabilities
Get = false
RawKvp =
{VERSION=1.3.0, SERVICE=wms, REQUEST=GetCapabilities}
BaseUrl = http://wppgeog3:8082/geoserver/
RequestCharset = null
2013-07-18 14:10:07,654 WARN [org.geoserver.wms.capabilities] - Map output format text/html does not include mime type in output format names. Will be excluded from capabilities document.
2013-07-18 14:10:07,654 WARN [org.geoserver.wms.capabilities] - Map output format application/xml does not include mime type in output format names. Will be excluded from capabilities document.
2013-07-18 14:10:07,665 ERROR [org.geoserver.ows] -
org.geoserver.platform.ServiceException: javax.xml.transform.TransformerException: java.lang.NullPointerException
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Response.write(Capabilities_1_3_0_Response.java:49)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:919)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:276)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.flow.controller.IpBlacklistFilter.doFilter(IpBlacklistFilter.java:87)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:46)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:103)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:615)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
at org.apache.coyote.http11.Http11AprProcessor.process(Http11AprProcessor.java:879)
at org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionHandler.process(Http11AprProtocol.java:600)
at org.apache.tomcat.util.net.AprEndpoint$Worker.run(AprEndpoint.java:1703)
at java.lang.Thread.run(Unknown Source)
Caused by: javax.xml.transform.TransformerException: java.lang.NullPointerException
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(Unknown Source)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:300)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:112)
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Response.write(Capabilities_1_3_0_Response.java:47)
… 79 more
Caused by: java.lang.NullPointerException
at org.geoserver.security.SecureCatalogImpl.buildWrapperPolicy(SecureCatalogImpl.java:731)
at org.geoserver.security.SecureCatalogImpl$2.evaluate(SecureCatalogImpl.java:1459)
at org.geoserver.security.SecureCatalogImpl$2.evaluate(SecureCatalogImpl.java:1453)
at org.geotools.filter.FilterAbstract.eval(FilterAbstract.java:129)
at org.geotools.filter.MultiCompareFilterImpl.evaluate(MultiCompareFilterImpl.java:67)
at org.geotools.filter.AndImpl.evaluate(AndImpl.java:57)
at org.geoserver.catalog.impl.DefaultCatalogFacade$1.apply(DefaultCatalogFacade.java:1168)
at org.geoserver.catalog.impl.DefaultCatalogFacade$1.apply(DefaultCatalogFacade.java:1164)
at com.google.common.collect.Iterators$7.computeNext(Iterators.java:649)
at com.google.common.collect.AbstractIterator.tryToComputeNext(AbstractIterator.java:143)
at com.google.common.collect.AbstractIterator.hasNext(AbstractIterator.java:138)
at org.geoserver.catalog.util.CloseableIteratorAdapter.hasNext(CloseableIteratorAdapter.java:45)
at com.google.common.collect.Iterators$8.hasNext(Iterators.java:807)
at com.google.common.collect.Iterators$7.computeNext(Iterators.java:647)
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Transformer$Capabilities_1_3_0_Translator.filterNestedGroups(Capabilities_1_3_0_Transformer.java:1048)
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Transformer$Capabilities_1_3_0_Translator.handleLayerGroups(Capabilities_1_3_0_Transformer.java:1030)
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Transformer$Capabilities_1_3_0_Translator.handleLayers(Capabilities_1_3_0_Transformer.java:667)
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Transformer$Capabilities_1_3_0_Translator.handleCapability(Capabilities_1_3_0_Transformer.java:430)
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Transformer$Capabilities_1_3_0_Translator.encode(Capabilities_1_3_0_Transformer.java:265)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:977)
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transformIdentity(Unknown Source)
… 85 more
2013-07-18 14:10:07,666 INFO [org.geoserver.flow] - Running requests: -106, processing through flow controllers: 0
Project:
Priority:
MajorMajor
Reporter:
Jonathan Moules
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
