Issue Type:
Bug
Affects Versions:
2.3.3
Assignee:
Niels Charlier
Components:
CSW
Created:
25/Jul/13 12:42 PM
Description:
Going through the CSW tutorial as part of copyediting, and found that many of the requests returned errors.
I was able to install the CSW module correctly (capabilities worked fine), and I believe I created the <data_dir>/csw/MD_Metadata file correctly, but the requests that follow in the tutorial all return NPEs. For example:
http://localhost:8080/geoserver/csw?service=CSW&version=2.0.2&request=GetRecords&typeNames=gmd:MD_Metadata&resultType=results&elementSetName=full&outputSchema=http://www.isotc211.org/2005/gmd
returns
<ows:ExceptionReport version="1.0.0" xsi:schemaLocation="http://www.opengis.net/ows http://localhost:8090/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd">
<ows:Exception exceptionCode="NoApplicableCode">
<ows:ExceptionText>java.lang.NullPointerException
null</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
Environment:
Windows 7, Tomcat 6.0, WAR install
Fix Versions:
2.3.5
Project:
Priority:
Minor
Reporter:
Mike Pumphrey
If you think it was sent incorrectly, please contact your JIRA administrators
For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
