[Geoserver-devel] [jira] (GEOS-6026) WMS url doesnt accept styles defined in Workspace
Brian Hamlin created BugGEOS-6026
Issue Type:
BugBug
Affects Versions:
2.3.0
Assignee:
Andrea Aime
Components:
WMS
Created:
10/Sep/13 11:08 PM
Description:
There may be a technical workaround, but its not obvious… so I file a bug.
I have a PostGIS table with 200 columns… to view a column, I defined a style with filter attributes… so the layer name is always the same, but many many styles.
When finally using WMS directly, I found that I could not append style= or styles= to the IRL to get an image… it replied ‘style does not exist’… The style was defined in the same workspace as the layer…
On IRC Tom Kunicki suggested I redefine the style “globally”, with no workspace. This in fact worked… Please note that QGis 1.8 from the GetCapabilities also got it wrong. SO, its not just me being un-informed.
Environment:
openJDK 7, ubuntu linux server
Project:
Priority:
MinorMinor
Reporter:
Brian Hamlin
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
