[Geoserver-devel] [jira] (GEOS-6108) Rest API cannot delete a store with a . in the name
Chantal Pritchard created BugGEOS-6108
Issue Type:
BugBug
Affects Versions:
2.1.4
Assignee:
Andrea Aime
Created:
23/Oct/13 12:10 PM
Description:
Using Rest API to try to delete a store coverage called ‘AB_UTM11_0.4m_2012_reharvest’ results in the following error:
2013-10-23 09:23:37,737 ERROR [geoserver.rest] - No such coverage store: nwgeo,AB_UTM11_0
org.geoserver.rest.RestletException
at org.geoserver.catalog.rest.CoverageStoreFinder.findTarget(CoverageStoreFinder.java:31)
2013-10-23 09:23:37,746 INFO [org.geoserver] - Loaded store ‘AB_UTM11_0.4m_2012_reharvest’, enabled
2013-10-23 09:23:37,746 ERROR [geoserver.rest] - :Store ‘AB_UTM11_0.4m_2012_reharvest’ already exists in workspace ‘nwgeo’
org.geoserver.rest.RestletException: java.lang.IllegalArgumentException: Store ‘AB_UTM11_0.4m_2012_reharvest’ already exists in workspace ‘nwgeo’
It appears that it is having problems with the . in the file name
Project:
Priority:
MajorMajor
Reporter:
Chantal Pritchard
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
