Richard Duivenvoorde created |
Issue Type: |
Affects Versions: |
2.4.2 |
Assignee: |
Components: |
CSS |
Created: |
05/Dec/13 6:31 AM |
Description: |
Trying to style a workspace point layer using css workspace style with an example from: http://docs.geoserver.org/latest/en/user/extensions/css/cookbook_point.html#point-as-graphic The global data styles dir is in: file:/d:/data/geoserver2.4.x/data_dir/styles/ While the created namespace styles are in: d:\data\geoserver2.4.x\data_dir\workspaces\myworkspace\styles Trying to use this:
I see that the url in the sldf wants the image now in: file:/d:/data/geoserver2.4.x/data_dir/styles/smileyface.png While I think, usign an image in a workspace style should also look for its images in the workspace/style folder: file:/d:/data/geoserver2.4.x/data_dir/workspaces/myworkspace/styles/smileyface.png As a workaround I thought to use the full path in the css:
But then the sld path becomes: <sld:OnlineResource xmlns:xlink=“http://www.w3.org/1999/xlink” xlink:type=“simple” xlink:href=“file:/d:/data/geoserver2.4.x/data_dir/styles/d:/data/geoserver2.4.x/data_dir/workspaces/myworkspace/styles/smileyface.png”/> Which is also wrong I think. Last idea:
Ah that one is working But I think this is a workaround? It would be nicer if defining a file name as mark:url the searchpath would be in the workspace/style directory (in case of a style from a workspace) |
Project: |
Priority: |
Reporter: |
