[Geoserver-devel] [jira] (GEOS-6339) Add documentation to ImageMosaic module
Daniele Romagnoli created an issue
GeoServer / TaskGEOS-6339
Issue Type:
TaskTask
Assignee:
Daniele Romagnoli
Components:
Documentation
Created:
07/Feb/14 8:46 AM
Priority:
MinorMinor
Reporter:
Daniele Romagnoli
With GEOT-4666 we are going to add support to PostGIS DB create/drop on imagemosaic (no more needs to pre-create a postgis db when using a mosaic).
We should add a couple of lines in the documentation to explain how it works.
Special notes are required about Postgresql/Postgis versions.
On Postgresql 9.1 with PostGIS 2 no additional configuration setting is required.
With lower version, you should add this parameter within the datastore.properties
create\ database\ params=WITH\ TEMPLATE=template_postgis
(Specifying the proper postgis template… in this example: template_postgis).
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
