Richard Duivenvoorde created an issue |
elevation based ranges for animated gif wms output does is squashed when ranges overlap |
Issue Type: |
Affects Versions: |
2.5, 2.6-beta |
Assignee: |
Attachments: |
panden1.gif, panden2.gif, panden3.gif |
Components: |
WMS |
Created: |
08/May/14 3:28 PM |
Environment: |
windows, java 1.7, geoserver 2.5, but also unstable geoserver 2.6 dd 22.04 |
Priority: |
Reporter: |
Having a shapefile here with 32 houses of a small city, having one attribute ‘building year’. Goal was to have an animated gif in which you see the city grow from a conglomerate of small towns to current city. Used Dimensions/Elevation/column ‘buildingyear’ for use of dimensions. Most stuff works: I can get one year of building, and even the animated gif is working wit individual years like: (panden1.gif) Then the I tested ranges: yes, working: panden2.gif BUT the goal is to see ‘the city grow’ so I want to add the new range on top of the old range. One solution for this, is to have ‘overlapping’ ranges, like: 1900/1950,1900/2000,1900/2100 see panden3.gif BUT now geoserver will not generate an animated gif anymore, but it looks like it ‘inteliligently’ concludes: "hey all together that is form 1990 to 2100, so let’s just sent ONE image with all house? So question: is this by design? Or is it a bug? If in need of testdata, just sent an email to richard@anonymised.com and I will sent you this shapefile |
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c) |
