[Geoserver-devel] [jira] (GEOS-6614) Changes in default interpolation option in WMS-settings has no effect.
Hans Gunnar Steen created an issue
GeoServer / BugGEOS-6614
Issue Type:
BugBug
Affects Versions:
2.5.2, 2.4.7, 2.5.1, 2.6-beta
Assignee:
Andrea Aime
Components:
WMS
Created:
14/Aug/14 4:27 AM
Environment:
CentOS 6.5, Java 1.7 & 1.8
Priority:
MajorMajor
Reporter:
Hans Gunnar Steen
Having recently switched from Geoserver 2.5.0 to 2.5.1, we have become aware of an unfortunate change in the way the WMS renders rasters. We have a postgis vector database with topographic data. As backdrop, we use the image mosaic
plugin with hillshades tiles.
In 2.5.0, the hillshades where easy to render smoothly (despite a relative course resolution) by adjusting the WMS default raster rendering interpolation from “Nearest neighbor” to “Bilinear” or “Bicubic”. Transferring the same setup to 2.5.1, changing
the interpolation method has no effect any more, “Nearest neighbor” (or, perhaps no interpolation at all) seems to be used no matter what setting we use, rendering nasty pixel borders on the innermost zoomlevels.
We’ve done some testing with different versions, and it seems that changing the interpolation worked fine in 2.4.6, failed in 2.4.7, worked fine again in 2.5.0 and failed again in 2.5.1 and all later versions including 2.6 beta.
The image mosaic tiles have the same resolution, bit depth and coordinate system (EPSG:3857). Asking the WMS in another coordinate system is not relevant to this problem, as it occurs in 3857 as well.
Attached is a comparison of the same area. 2.5.1 vs 2.5.0, both set to use bilinear interpolation:
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
