DescribeFeatureType does not return a property when the property is ‘name’.
Edit layer in the web interface lists the following properties:
the_geom
name
road_surfa
road_highw
The request
http://65.99.241.240/geoserver-2.6.0/wfs?version=1.1.1&request=DescribeFeatureType&typename=Taranaki%3Aroads-centrelines
returns
<xsd:schema elementFormDefault=“qualified” targetNamespace=“http://65.99.241.240/geoserver-2.6.0/workspaces/Taranaki”>
<xsd:import namespace=“http://www.opengis.net/gml/3.2” schemaLocation=“http://65.99.241.240:80/geoserver-2.6.0/schemas/gml/3.2.1/gml.xsd”/>
<xsd:complexType name=“roads-centrelinesType”>
<xsd:complexContent><xsd:extension base=“gml:AbstractFeatureType”>
<xsd:sequence>
<xsd:element maxOccurs=“1” minOccurs=“0” name=“the_geom” nillable=“true” type=“gml:MultiCurvePropertyType”/>
<xsd:element maxOccurs=“1” minOccurs=“0” name=“road_surfa” nillable=“true” type=“xsd:string”/>
<xsd:element maxOccurs=“1” minOccurs=“0” name=“road_highw” nillable=“true” type=“xsd:string”/>
</xsd:sequence>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
<xsd:element name=“roads-centrelines” substitutionGroup=“gml:AbstractFeature” type=“Taranaki:roads-centrelinesType”/>
</xsd:schema>
i.e. the ‘name’ property is missing.
Note: If version is changed to 1.0.0, then the ‘name’ property is returned
