David K created an issue |
Issue Type: |
Affects Versions: |
2.6.0, 2.5.2 |
Assignee: |
Components: |
Importer |
Created: |
25/Mar/15 1:50 PM |
Environment: |
I use “Platform Independent Binary” all the time. My system is Windows 8.1 64bit. 8GB ram, Intel I5 4670K. |
Priority: |
Reporter: |
Original Estimate: |
5 hours |
Remaining Estimate: |
5 hours |
I use GeoServer in local environment to work on one project, which deals with publication of rasters (8 bit PNG with size of 5 to 40 MB; indexed pallete with one color index for full transparency; georeferenced AND RECTIFIED in ArcMap). Using the localhost:8080 I imported almost 40 rasters as a world file, but for maybe 5 of them I get this error: "Could not list layers for this store, an error occurred retrieving them: Failed to create reader from file:data/dp/2374/rectify/2374rect3857.png and hints nullâ For some weird reason, I couldn’t do anything with it, but then I find out, that when I rectify same map from ArcMap with same settings again, I get rid of this error (sometimes it managed to add worldfile for 3rd or 4th rectification). I am not sure, how is it in newer versions, because this error is hard to replicate - or if anyone here was dealing with it and it was fixed already. Have a nice day! |
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c) |
