Chrstian Mueller created an issue |
Issue Type: |
Affects Versions: |
2.8-M0, 2.7.1 |
Assignee: |
Components: |
Security |
Created: |
14/Jun/15 4:49 PM |
Fix Versions: |
2.7.2, 2.8.0 |
Priority: |
Reporter: |
The security test setup contains a keystore (geoserver.jceks) incompatible with IBM java. This setup breaks a lot of tests. The keystore itself works with ORACLE and OpenJDK, no problems here. The idea is to inspect the content of the “java.vendor” property and use a special IBM keystore if the tests are running on IBM Java. ORACLE and IBM do not attach the source code of their keystore implementations. As a consequence, this could be the easiest solution. |
This message was sent by Atlassian JIRA (v6.5-OD-05-041#65001-sha1:e07c9f6) |
