[Geoserver-devel] [JIRA] (GEOS-7072) Random test failure in REST, CoverageStoreTest
Andrea Aime [Administrator] created an issue
GeoServer / BugGEOS-7072
Issue Type:
BugBug
Assignee:
Unassigned
Created:
15/Jun/15 2:05 PM
Priority:
MediumMedium
Reporter:
Tests run: 23, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 11.173 sec <<< FAILURE!
org.geoserver.catalog.rest.CoverageStoreTest  Time elapsed: 1132 sec  <<< ERROR!
java.io.IOException: Unable to delete directory ./target/default5487506170731746609data.
	at org.apache.commons.io.FileUtils.deleteDirectory(FileUtils.java:1337)
	at org.geoserver.data.test.SystemTestData.tearDown(SystemTestData.java:967)
	at org.geoserver.test.GeoServerBaseTestSupport.doTearDownClass(GeoServerBaseTestSupport.java:206)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at java.lang.reflect.Method.invoke(Method.java:606)
	at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:33)
Since this is Linux, it should not be a locking issue… maybe the folder was already deleted by some other means?
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.5-OD-05-041#65001-sha1:e07c9f6)
Atlassian logo
