[Geoserver-devel] [JIRA] (GEOS-7153) Closing Resources OutputStream bug
Jody Garnett [Administrator] created an issue
GeoServer / BugGEOS-7153
Issue Type:
BugBug
Assignee:
Unassigned
Created:
12/Aug/15 1:18 AM
Priority:
MediumMedium
Reporter:
From github 1176(https://github.com/geoserver/geoserver/pull/1176)::slight_smile:
According to the Closeable API (http://docs.oracle.com/javase/7/docs/api/java/io/Closeable.html#close%28%29 ) the close method should not throw (or cause, in this case) an exception when called on an already closed resource. The FileSystemResource and ResourceWrapper do do this.
The pull request also includes the request to make Resource.delete() recursive, this functionality is handled by Resources.delete( res ) to make the ResourceStore API easier to implement.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.5-OD-08-001#65007-sha1:1fc9846)
Atlassian logo
