[Geoserver-devel] [JIRA] (GEOS-7171) Geoserver WMS Circle SLD style return incomplete Circle with higher zoom levels
Ahmed GIS created an issue
GeoServer / BugGEOS-7171
Issue Type:
BugBug
Affects Versions:
2.6.4
Assignee:
Unassigned
Components:
WMS
Created:
25/Aug/15 10:09 AM
Environment:
I’m Using Windows 7 Ultimate 64 bit, OpenGeo Suite v2.5
Labels:
WMS Tile Cache SLD Cirlce Graphic Render
Priority:
MediumMedium
Reporter:
Ahmed GIS
I created a SLD style for a points layer and create 2 rules:
Rule to draw a graphics icon from png file.
Rule to draw a circle with radius(size) from db table using (OGC Attribute) value in meters.
I use the following code to load the layer in OL3:
var wmsSource = new ol.source.TileWMS ({
    url: 'http://localhost:8080/geoserver/wms',
    params: {'TILED': true, VERSION:'1.3.0',
       'LAYERS': 'myds:antenna',
    serverType: 'geoserver'
new ol.layer.Tile({
         title: 'Antennas',
         visible: true ,
         source:wmsSource
The layer loaded correctly on the map in some lower zoom levels (0-10) if i zoomed in to more levels down (11-17) the circle shape is trimmed by the tiles like the attached image.
WMS Graphics Circle Error
The strange thing when i set the 2nd rule in the SLD that to get a fixed radius value like (2000) meters - Not from db table -, it draw a complete circle in all zoom levels, but i need to set a different radius for each circle.
I tried many solutions to avoid this error by changing the metatiling factors (4x4, 5x5, …, 100x100)and change the Gutter to be 100px, it solve the problem but affect the loading speed badly also i tried to set the WMS layer params:
{‘TILED’: false}
to disable tiles but nothing changed also, same problem.
Here’s my question with images in http://gis.stackexchange.com/:
My StackExchange Question
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.0.0-OD-02-247#70102-sha1:09808d3)
Atlassian logo
