[Geoserver-devel] [JIRA] (GEOS-7221) Document how to debug GeoServer with extensions
Torben Barsballe created an issue
GeoServer / BugGEOS-7221
Issue Type:
BugBug
Assignee:
Unassigned
Created:
28/Sep/15 9:07 PM
Priority:
MediumMedium
Reporter:
Torben Barsballe
The geoserver manual has instructions for debugging geoserver from eclipse; however a default build will result in a geoserver with no extensions.
In order to debug geoserver with extensions, the web-app must be built with certain profiles, which pull in the required dependancies. Instructions on how to do this should be added to the Quickstart and (optionally) the eclipse guide sections of the GeoServer documentation.
This should reduce the instances of new developers using other, less reliable methods of debugging extensions (eg. copying jars into the eclipse classpath).
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.0.0-OD-07-011#70107-sha1:db940e9)
Atlassian logo
