Darshan Lingegowda created an issue |
Issue Type: |
Affects Versions: |
2.8.0 |
Assignee: |
Unassigned |
Attachments: |
default.style, osm_highway.sld |
Components: |
PostGIS |
Created: |
03/Nov/15 4:18 PM |
Environment: |
Windows 7 , Java 1.7 , PostgreSql 9.4 |
Labels: |
sld openlayer |
Priority: |
Reporter: |
I have written an sld to visualize the lines of the osm data of hamburg which I have converted to postgis format using osm2pgsql and then imported this postgis data into geoserver. The sld is styled to render the map feature:- highway(roads) with all its principle tags which works fine and can been seen but there are some roads for example secondary roads (August-Krogmann-Straße,Berner Chaussee Kirchwerder Landweg) etc to name a few which seem to be rendered incomplete i.e. they appear like disjoint line with some parts missing at all zoom levels(like dash array lines) instead of a continuous line. And there are no errors in the log file of the geoserver, no tile caching error and no java errors. I have tried using different sld’s(online Github) but still this problem exists. |
This message was sent by Atlassian JIRA (v7.0.0-OD-08-005#70107-sha1:5fb2f7e) |
