[Geoserver-devel] [JIRA] (GEOS-7328) no native SRS/bbox from postgis when schema not specified in store
CAL created an issue
GeoServer / BugGEOS-7328
Issue Type:
BugBug
Affects Versions:
2.8.0, 2.7.2
Assignee:
Unassigned
Components:
Configuration, PostGIS
Created:
02/Dec/15 4:43 PM
Environment:
RHEL 6.5
Tomcat 8.0.23
Oracle JDK 1.7.0.76
Postgresql 9.4.4
Postgis 2.1.8
Labels:
geoserver
Priority:
MediumMedium
Reporter:
CAL
when a schema is not defined in a Postgis store, nativeSRS and native Bouding box are not automatically recognized (“compute from data” cause exceptions even If Declared SRS is defined)
java.lang.RuntimeException: java.io.IOException: Error occured calculating bounds for cad_bati_t
at org.geotools.jdbc.JDBCFeatureSource.getBoundsInternal(JDBCFeatureSource.java:540)
at org.geotools.data.store.ContentFeatureSource.getBounds(ContentFeatureSource.java:428)
at org.geotools.data.store.ContentFeatureSource.getBounds(ContentFeatureSource.java:364)
at org.vfny.geoserver.global.GeoServerFeatureSource.getBounds(GeoServerFeatureSource.java:660)
at org.geoserver.catalog.CatalogBuilder.getNativeBounds(CatalogBuilder.java:561)
at org.geoserver.catalog.CatalogBuilder.getNativeBounds(CatalogBuilder.java:543)
at org.geoserver.web.data.resource.BasicResourceConfig$1.onSubmit(BasicResourceConfig.java:120)
at org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubmitLink.java:68)
at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(AjaxFormSubmitBehavior.java:143)
at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:177)
at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:300)
at org.apache.wicket.request.target.component.listener.BehaviorRequestTarget.processEvents(BehaviorRequestTarget.java:119)
at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92)
at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:160)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:648)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:159)
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.1.0-OD-02-025#71001-sha1:64a64e8)
Atlassian logo
